Conference Tones
Answered Question
Aug 3rd, 2010
Is there a way from within CCA to disable the conference tones for Cbarge, Meet-Me, and Ad-hoc (using Join button)?
I know how to do this via CLI.  If this is done via CLI will it break CCA?  Would this be considered an out of band configuration item?
Mario
Correct Answer by antyeung about 6 years 6 months ago
Unfortunately CCA does not give you the option to enable/disable the join/leave tones. They are configured by default. If you use the software resources (IOS) for 3-party conferences (uncheck Enable Multi-Party Conferencing and select Max 3-way calling sessions) it would not play join/leave tones for ad-hoc conferencings. But you only get ad-hoc conferencing - no meet-me or more than 3-party ad-hoc/meet-me. You also would be disabling cBarge.
If you remove it OOB, I don't see it causing a problem with CCA since all CCA does is remove or add these commands when you enable/disable hw conferencing.
dspfarm profile 1 conference
shut
no conference-join custom-cptone CCAjointone
no conference-leave custom-cptone CCAleavetone
no shut
However, I don't recommend getting into the habit of doing OOB configurations since it's a very gray area and the behavior of how CCA implements a feature may change b/w versions.
Anthony Yeung
Technical Marketing Engineer
Small Businss Technolog Group
Overall Rating: 5 (1 ratings)
Correct Answer
antyeung Tue, 08/03/2010 - 11:49
shut
no shut
Anthony Yeung
Mario Garcia Tue, 08/03/2010 - 12:10
Thanks Anthony, I justed want to ensure that removing the tones using CLI would not inhibit CCA functionality with the UC.
