s2s vpn along with pat
Answered Question
Aug 3rd, 2010
  • Silver, 250 points or more
Hi all ,
              I have to establish s2s vpn to my client networks
my internal network 192.168.1.x 255.255.252.0 would require access to entire 10.0.0.0/8 client network via s2s vpn , But client does nt want us to send real IP source to access their resource , they ask us to PAT entire IP subnet to  IP 192.16.x.x for accessing 10.0.0.0/8 .
Similarly whether this setup would have realibilty to S2S connection , kindly help in coomands , Thank you
Correct Answer by Nagaraja Thanthry about 6 years 11 months ago
If I understand you right, you are interested in seeing if the internal
clients can use a public IP when they go to the remote vpn subnet. As long
as that public IP is not the interface IP (VPN end point ip address), it
should be fine.
As far as your question about reliability is concerned, could you please
elaborate on what do you mean by reliability? As it is, it is a general IP
communication and it will not affect any other system (unless there is a
conflicting configuration).
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Tue, 08/03/2010 - 12:07
  • Cisco Employee,
You can use policy nat to achieve what you are looking for:
access-list pnat permit ip 192.168.1.0 255.255.252.0 10.0.0.0 255.0.0.0
global (outside) 100 192.16.0.0 netmask 255.255.252.0
nat (inside) 100 access-list pnat
access-list cryptomap permit ip 192.16.0.0 255.255.252.0 10.0.0.0 255.0.0.0
This will map the 192.168.1.0 subnet to 192.16.0.0 subnet when accessing
10.0.0.0/8 network.
Hope this helps.
NT
SANTHOSHKUMAR S... Tue, 08/03/2010 - 12:14
Hi Raj ,
                Thanx so much for response ,  whether ip can use public IP address as PAT IP, so that PAT IP traffic would be encrypted inside tunnel , similarly let us know this kind of setup would have network relability . Thank you ..
Correct Answer
Nagaraja Thanthry Tue, 08/03/2010 - 13:06
  • Cisco Employee,
should be fine.
Hope this helps.
NT
