remote
pcfreak49
hello I small problems I Cisco router 800 serials now I remote wants work by means of SSH and telnet now are my question how can you this do?
who can help me
4 Accepted Solutions
Jennifer Halim
You should be able to telnet to the router on the WAN/external ip address remotely if telnet is not disabled.
For SSH, you have to generate RSA keypair before you can SSH to the router. Here is the sample configuration for SSH:
http://www.cisco.com/en/US/customer/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Hope that helps.
sorry, i don't quite understand what you mean.
Telnet locally works, however, telnet from external is timing out?
Are you getting the password prompt when you try to telnet from external? If not, then there is probably access-list on the interface that blocks telnet, OR/ under "line vty", it's only allowing internal address range.
do you have a copy of the router configuration? I can check and let you know what to add/change.
I don't understand what you mean.
26 Replies 26
Jennifer Halim
Hope that helps.
no telnet are not disabled. because is possible inlogen local but externally succeed that because krijg time out must there sometimes something to fit become?
yes that is correct telnet local works but externally does not work it how can you that access trick make for telnet?
kind regards
yes I have copy of running-config
possible you is something lets know what be adapted there must?
OK, base on the configuration, you have ZBFW (Zone Base Firewall) configured. Hence you would need to allow the traffic between out-zone and self-zone.
Here is what you would need to configure to allow telnet access:
class-map type inspect match-any telnet-class
    match protocol telnet
policy-map type inspect ccp-permit
    class type inspect telnet-class
        inspect
Hope that helps.
yes it works external telnet cordial thanks
do you know sometimes how that with SSH also are possible?
kind regards
Sure, for SSH just add this:
    match protocol ssh
there does this have still something changes become?
kind regards
You would also need to generate the RSA keypair: crypo key generate rsa
You also need to use SSH Client software (eg: Putty, SecureCRT) to SSH to the router.
those RSA key I have produced and used putty must still something change become?
kind regards
Mmmm.. where does it break?
Are you able to telnet on port 22?
Are you prompted for username and password?
Or the connection just hang?
Can you share the latest configuration again pls.
yes that is no problem this is new running-config
I have telnet geprobeert as from another isp and then work
mvg
