question on "Backup Interface"
Answered Question
Aug 3rd, 2010
Got question on "Backup Interface"
Can Backup Interface be a  good option to pass the traffic when primary GRE Tunnel goes down at Branch
**Scenario:**
Dual VPN Hub at HQ pointing to different ISP
Branch would have one GRE tunnel each pointing to Hub1 and Hub2.
For Branch VPN-Hub 1  is always primary and if VPN-Hub 1 is not reachable then all traffic goes via VPN-Hub2
**Branch **
inter tun 1   //# Connected to Hub1
ip address 1.1.1.1 255.255.255.252
tunnel source fa 0/1
tunnel destination 9.9.9.9
backup interface tunnel 2
backup load 80 10
inter tun 2   //# Connected to Hub2
ip address 2.2.2.2 255.255.255.252
Correct Answer by Giuseppe Larosa about 6 years 6 months ago
Hello Saquib,
GRE tunnels allows to use dynamic routing protocols over them
rather then attempting to use backup interface I would run EIGRP or OSPF over the tunnels
by tuning costs you can easily have tunnel 1 primary and tunnel 2 backup (higher OSPF cost or for EIGRP higher delay set on tunnel2)
to have tunnel 1 to fail like a physical interface you would need to use GRE keepalive:
without it a point to point GRE is considered up if local node has a route to tunnel destination.
with GRE keepalive enabled if local node stops to receive GRE keepalives it will put the tunnel in up/down state like a serial interface not receiving serial keepalives.
to enable keepalive you need to use the keepalive <#missedkeepalive>
in tunnel interface configuration mode on both routers (also on GRE tunnel configured on remote node I mean)
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 08/03/2010 - 13:44
Hello Saquib,
Hope to help
Giuseppe
Richard Burts Tue, 08/03/2010 - 15:08
ST
I agree with Giuseppe that an alternative like running a dynamic routing protocol is better to have a second tunnel that backs up the primary.
I have not tested it but I am not sure that backup interface would even work on a virtual interface like a tunnel.
Rick
saquib.tandel Wed, 08/04/2010 - 01:33
Thank you both for replying.
I will test with ospf cost and do a lab with eigrp.
