Unity Connection 8.x Questions
dtran
Level 6
Level 6
Hi All,
I have two questions on Unity Connection 8.x cluster:
How do I check the database status to ensure that both Pub and Sub are in sync or if there's any replication in progress ?
What are the critical services that I should be monitoring on both Pub and Sub ?
Thanks in advance !!!
D.
You may already be aware of this doc. The following guide shows the services in Unity Connection that are critical:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/serv_administration/guide/8xcucservag040.html
It also gives definitions for all Connection services.
Scott
8 Replies 8
Scott Hills
Regarding the replication part of question you can run:
utils dbreplication status
This was addressed to be more relevant for Connection Database in CSCsy82798.
Hope that helps.
Scott
Scott
Hello Scott,
Below is the ouput from the command "utils dbreplication status" I ran on the Pub server. How would I tell if the DB on both Pub and Sub are in sync or there is replication in progress ?
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_w0as14_ccm8_0_2_40000_1    2 Active   Local           0
g_w0as15_ccm8_0_2_40000_1    3 Active   Connected       0 Aug  2 12:56:54
Thank you very much Scott !!! very much appreciate your help !!!
D.
Another command you could run is:
show cuc cluster status
The full command line reference with definitions of the commands can be found at the following link:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/cli_ref/8_0_2/cli_ref_802.html#wp45787
Scott
Hello Scott,
The link you sent is very helpful !!! I very much appreciate your help !!!
Do know what's the output of the "utils dbreplication status" looks like if the DBs are not in sync or if there is replication in progress ?
thanks again !!!
D.
I cannot answer that question. The defect/enhancement was only recently added to 8.x so I have not seen an instance myself at this point.
Scott
Thanks Scott !!!
Appreciate all your help !!!
D.
D. Tran,
Check out this post link.  It will outline all of the CUC services and what they do. https://supportforums.cisco.com/message/3120383#3120383
Hailey
Please rate helpful posts!
