Question about 3750G Stack
Answered Question
Aug 3rd, 2010
Hi All,
If the master switch in one 3750G stack failed, which slave will take control? Does the slave inherit all the settings from master?
Thanks a lot.
Lou
Correct Answer by Nagaraja Thanthry about 6 years 5 months ago
When the current master goes down, the slave switch will takeover the master
role and inherit all the settings from the master. Here is a document that
explains the master election. If all other parameters remain same, the
switch with lowest MAC ID will be selected as master.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configur...
n_example09186a00807811ad.shtml#election
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Tue, 08/03/2010 - 16:02
Hope this helps.
NT
