08-03-2010 06:56 PM - edited 03-11-2019 11:20 AM
My question is that I have a pair of FWSM that resides on a 6509 and when the primary went down the secondary was active.
When the primary came up, the secondary was still the active FW.
Here is the config for the primary and secondary part on the FWSM (IPs changed) :-
failover
failover lan unit primary
failover lan interface Failover Vlan74
failover link State Vlan75
failover interface ip Failover 10.4.10.67 255.255.255.248 standby 10.4.10.68
failover interface ip State 10.4.7.74 255.255.255.248 standby 10.4.7.75
failover
failover lan unit secondary
Is there a way to make the primary active when it comes back up ? Ie) Similar to using the 'preempt' command for HSRP.
Please advice,
Cheers,
- SN -
Solved! Go to Solution.
08-03-2010 07:03 PM
Sanjay,
The 'failover preempt' command might help you here:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/command/reference/ef.html#wp1667787
It is only available in 3.2.x, 4.0.x. and 4.1.x.
- Magnus
08-03-2010 07:03 PM
Sanjay,
- Magnus
08-03-2010 07:20 PM
Thanks Magnus
Cheers,
- SN -
