Cisco Nexus 5010
Answered Question
Aug 3rd, 2010
I saw a Cisco Nexus 5010 and it has 5 RJ-45 port, 1 for Console, 2 for MGMT and another two port for what ??? L1 and L2, somebody can explain me that ?? Thank yuo so much !!!
Correct Answer by Jayakrishna Mada about 6 years 11 months ago
Konus,
The defect id is to document that the ports are not usable, this was not documented. ( did not intend to confuse you).
The first 8 ports on 5010 can be used to as 1 gig ports with GLC-T= transceiver.
JayaKrishna
Overall Rating: 5 (2 ratings)
Jayakrishna Mada Tue, 08/03/2010 - 19:31
  • Cisco Employee,
Hi ,
Only one port works our of those 4 ports. L1/L2/MGMT1 are not usable yet and will be used in future. A document defect is opened to document this. Defect id: CSCth37349
Hope that answers your question.
JayaKrishna
goransh_pc Tue, 08/03/2010 - 19:56
Thank you so much for your quick feedback JayaKrishna, but right now I'm more confused than before:
Waht is a Defect ID: CSCth37349 ?
All usable ports on that switch (Nexus) are SFP, is there any adapter that permits to connect NIC server or NIC pc to the Nexus through RJ-45 and UTP cable?
Thank you so much
Correct Answer
Jayakrishna Mada Tue, 08/03/2010 - 20:08
  • Cisco Employee,
Konus,
JayaKrishna
