Transformation from CUCM Directory 2 IP Phone Ext whats the best way
Aug 3rd, 2010
CUCM Sync with AD at present
Currently numbers from corporate directory are coming through as 8 digits.
Thats the way customer wants to leave it.
Where should we perform a transformation back to 4 digit extension. So Transparently the 10 digit  directory number turns to 4 and IP phone is dialed.
1, Create Called Party Tranformation matching the 8 digits then strip to 4 digits [called party transformation mask] Place this transformation  into site specific Partition.
Would that work?
Is there a another or prefered option
Joseph Martini Sat, 08/07/2010 - 06:12
  • Cisco Employee,
You'll want to use translation patterns for chaning call routing.  The transformations are for called/calling number normalization more so than call routing.  Here's some more informtion on the transformations for number normalization if you're interested: http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fscallpn.html#wp1289039.
