AP1131 Session Limited
Aug 4th, 2010
We have two AP1131G-E-K9 Module configured as LWAPP (Standalone) Version - 12.4(10b)JA
When Client is trying to download file from Internet via Wireless he is getting limited of speed to 300Kbps, While when same Client Connected via LAN he is getting 1.5Mbps of Downloading from Internal.Those Access Point setting on same Vlan and same Cisco Switch 2960.
Both Test Connection setting on same Vlan's and Cisco Switch.
I'm asking if there is some Limition of Session or there is any problem with my Configuration/Software Version :
version 12.4
no service pad
service password-encryption
hostname XXX
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa session-id common
no ip dhcp use vrf connected
ip dhcp excluded-address 172.27.55.200 172.27.55.254
ip dhcp excluded-address 172.27.55.1
ip dhcp pool dhcp_wifi
   network 172.27.55.0 255.255.255.0
   default-router 172.27.55.254
   dns-server 194.73.82.242 194.72.9.34
   netbios-node-type h-node
   lease 0 1
dot11 ssid XXXX
   authentication open
   guest-mode
ssid XXXX
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
no preamble-short
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.27.55.251 255.255.255.0
no ip route-cache
ip default-gateway 172.27.55.254
ip http server
no ip http secure-server
snmp-server community public RO
bridge 1 route ip
line con 0
line vty 0 4
end
Leo Laohoo Wed, 08/04/2010 - 02:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
How far is this client from the nearest AP?
Is the Wireless NIC of the client running updated firmware?
What is the signal and SNR values?
Straight line from the AP or around the corner?
elbaz_eyal Wed, 08/04/2010 - 05:23
The Client is near to AP around 5m.
The Dirver Client is Updated (it's apend more then one Laptops).
The Signal is : -64dBm
The SNR is : 29dBm
The AP setting on the ceiling and Client at his desktop.
Leo Laohoo Wed, 08/04/2010 - 05:33
  • Hall of Fame,
    2017 LAN, Wireless
And the link between the AP and the switch is 100 Mbps, Full?
elbaz_eyal Wed, 08/04/2010 - 05:41
Yep, The Interface Fast0/0 on AccessPoint is 100Mb Full Duplex
Also at the Cisco Switch 2960.
George Stefanick Sun, 08/08/2010 - 13:19
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Sounds like its on the wireless end. Change your channel, even perhaps move to 802.11a ONLY and test ...
