EIGRP goes down before line protocol
Aug 4th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
I am tying to understand this wierd behaviour when a WAN link goes down.
The below logs are from a cisco 7304 router.
Jul 19 08:31:57.704: %DUAL-5-NBRCHANGE: IP-EIGRP(0)  100: Neighbor 164.55.222.105 (POS3/0) is down: holding time expired
Jul 19 08:32:21.124: %LINEPROTO-5-UPDOWN: Line  protocol on Interface POS3/0, changed state to down
Jul 19 13:34:40.276: %DUAL-5-NBRCHANGE: IP-EIGRP(0)  100: Neighbor 164.55.222.105 (POS3/0) is up: new adjacency
Jul 19 13:34:41.204: %LINEPROTO-5-UPDOWN: Line  protocol on Interface POS3/0, changed state to up
If you notice when the interface actually went down, Eigrp hold timer expired before before the Line protocol shows down.
Is this behavior expected. Is there a way to fine tune the Line protocol to go down earlier and that trigger Eigrp, rather than EIGRP hold time expiring which would probably take 15 seconds for a OC3 link, hello time being 5sec.
Thanks.
gatlin007 Wed, 08/04/2010 - 07:51
  • Silver, 250 points or more
If the goal is to cause EIGRP to notice an unreliable link faster than 15 seconds than the hello/hold timers on that link could be adjusted.  This would need to occur on both sides of the link using the interface level 'ip hello-interval eigrp' and 'ip hold-time eigrp' commands.  Something like the following would cause eigrp to declare the link bad after 3 seconds.
int pos x/x
ip hello-interval eigrp 100 1
ip hold-time eigrp 100 3
### 100 is the AS number
Chris
victor_87 Wed, 08/04/2010 - 09:27
Hello Chris,
Thankyou for your response.
Indeed the Link loss can be identified faster by reducing the hello and Hold timers but we consider 15 sec is ok.
But i was trying to understand how much time a POS interface would actually to identify loss of framing when a link goes down and report a line protocol down on the Log.
In this case it is definitely taking more than 15 secs so thats a lot of time.
Victor
