08-04-2010 04:34 AM - edited 03-06-2019 12:18 PM
would you mind please helping me in an issue i experience in my
work at a customer premises network?
i have two sites, site A & B, i'm the administrator of site A.
because the low upload speed that is allowed in the dsl connections
in this area i had to subscribe for another dsl connection to maximize
the speed of the upload. the only traffic that will be transmitted
between the two sites is a video conference traffic, so i have to
use the two dsl links to transfer the video conference traffic between
the two sites, therefor i installed a cisco 2811 router that has two ethernet
interfaces f0/0 and f0/1, each one connected to one of the dsl modems
via an ethernet cable . and then to configure a load balancing on the
two ethernet interfaces to distribute the video traffic over the
dsl links,
some people say that the video traffic will not be allowed to be
transfered over the two dsl links by load balancing.
so my question is, does the load balancing configuration on cisco
2811 router will let me transfer the video conference traffic over
the two links successfully with a fast and acceptable performance?
and in this situation it will be better to use load balancing per
destination or load balancing per packet ?
i appretiate your urgent reply
many thanks
makar
Solved! Go to Solution.
08-04-2010 05:26 AM
unfortunately i don't find my case!!!
Highlight your name and a window will appear telling you your past posts.
You can also click on your name, click on the "Your Stuff" tab.
08-04-2010 05:28 AM
This is at least the third time that you have posted exactly the same question.
This is his 7th post. His first post was on 02 August 2010.
08-04-2010 04:39 AM
Makar
This is at least the third time that you have posted exactly the same question. And your previous postings have gotten responses. It is not good protocol for the forum to post the same question multiple times, without acknowledging the prior posts and without saying why the previous responses were not satisfactory.
Rick
08-04-2010 05:14 AM
hi Richard
i've already sent exactly the same question more than one time as you said. but really after some time i try to check if any one posted responses
but unfortunately i don't find my case!!! therefore i sent it again. the first time only which someone replied me and i was needing another better response
so i havn't acknowleded it becaues i expected someone else will give me a clearer response...
anyway really i didn't mean that to post many times the same question, but because the reasons i mentioned.
but if you read the last postings of me and your openion that the replies are the best answers, i'll try to delete this case now, not to bother anyone in the forum.
sorry again and thanks for your notification.
makar
08-04-2010 05:26 AM
08-04-2010 05:53 AM
oh my god...
really thanks leolaohoo for your reply, i found all the postings i sent.
because i'm not used with the forum and don't use it alot so i was using a poor method to find my posting, but now after your reply i found them.
sorry for inconvenience
makar
08-04-2010 05:28 AM
