dual line in cisco call manager 4.1
Answered Question
Aug 4th, 2010
Hi everybody,
How can i configure the dual line for one extension in call manager 4.1, i  need to be able to receive two call in the same extension.
Best regards
Correct Answer by Rob Huffman about 6 years 6 months ago
Hi Faycal,
If you go the phone in question via ccmadmin and check the DN config
page down towards the bottom of the page there is a setting;
Multiple Call / Call Waiting Settings
Maximum Number of Calls = (set to 4)
Busy Trigger = (set to 2)
Set these to 4 & 2 respectively and you will be able to receive 2 calls
on this number
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 08/04/2010 - 05:24
Hi Faycal,
on this number
Cheers!
Rob
