LMS 3.2 Dynamic UT Incorrect OID
Aug 4th, 2010
When I configure 3550 with mac-notification snmp traps to enable Dynamic User Tracking, I got incorrect OID in the macuhic.log and nothing happens with UT:
class com.cisco.nm.cm.ut.uhic.mac.AsnDecoder.AsnObject: CB-Error-incorrectoid: Skt IP Address: 10.128.145.17, Incorrect OID: 1.3.6.1.4.1.9.1.485, location ctxt: AsnMakeMe_snmp_v1, SNMPv1
Decoder Stage: deviceIP : null  timeStamp : 0  Processed : false
All is working well on these 3550s with LMS.
Please Help ?
Thanks in advance,
Patrice
Joe Clarke Wed, 08/04/2010 - 12:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You asked this in https://supportforums.cisco.com/thread/176483 .  I summarized the problem there as it was affecting the original poster.
Campus will only handle cmnMacChangedNotification traps.  If your switch is not generating these, then Dynamic UT will not work.  A sniffer trace filtering on udp/1431 will confirm the traps being received by Campus.
ppoiron Thu, 08/05/2010 - 01:00
Thanks Joe.
LMS is configured to get traps on udp/1431.
So, I will take a look on these received traps.
