Configuration of logging message on a syslog server in VRF environnement
Aug 4th, 2010
I have a problem with the configuration of logging on a VRF environnement.
The switch is a Ctalyst 3750 (version 12.2.53(SE2)).
The configuration is the following
version 12.2
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname test
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login nolog none
aaa session-id common
clock timezone FR-HIVER 1
clock summer-time FR-ETE recurring last Sun Mar 2:00 last Sun Oct 3:00
switch 1 provision ws-c3750g-24ts
system mtu routing 1500
authentication mac-move permit
udld aggressive
ip subnet-zero
ip routing
ip vrf SRV
ip vrf TOIP
ip vrf USR
port-channel load-balance src-dst-ip
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
spanning-tree etherchannel guard misconfig
spanning-tree vlan 1-1000 priority 4096
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport access vlan 3
switchport mode access
interface GigabitEthernet1/0/2
switchport access vlan 2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan2
description VLAN User
ip vrf forwarding USR
ip address 192.168.2.254 255.255.255.0
interface Vlan3
description VLAN SERVEUR
ip vrf forwarding SRV
ip address 192.168.3.254 255.255.255.0
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
logging trap
logging facility local7
logging host 192.168.3.1 vrf SRV
line con 0
password system
login authentication nolog
line vty 0 4
exec-timeout 60 0
privilege level 15
password system
logging synchronous
line vty 5 15
privilege level 15
password system
end
I have connected my syslog server on the port 3 (vlan 3 in VRF SRV) and I don't receive any syslog message.
I have tried with a default configuration (without VRF) and it's OK...
So, could you explain to me if I do a mistake on my configuration?
Regards.
Laurent.
Collin Clark Wed, 08/04/2010 - 06:41
  • Purple, 4500 points or more
Laurent-
We wanted to setup a management VRF and ran into the issue. TAC confirmed that you can't source logging from a VRF, it can only come from global.
Hope it helps.
r.laurent Wed, 08/04/2010 - 07:09
Hi Collin,
Thank your response.
I found this document (version 12.2SR) on the web (http://www.cisco.com/en/US/docs/ios/12_2sr/12_2sra/feature/guide/srvrfslg.html#wp1067039). This document explain the procedure to configure a syslog server in a VRF environnement. Is it obsolete?
On the userguide of the version of my catalyst 3750 (12.2.53(SE2)), we can find the following procedure :
User Interface for Syslog
Step 1configure terminal
Enter global configuration mode.
Step 1 : logging on
Enable or temporarily disable logging of storage router event message.
Step 2 : logging host ip address vrf vrf name
Specify the host address of the syslog server where logging messages are to be sent.
Step 3 : logging buffered logging buffered size debugging
Log messages to an internal buffer.
Step 4 : logging trap debugging
Limit the logging messages sent to the syslog server.
Step 5 : logging facility facility
Send system logging messages to a logging facility.
So, this procedure doesn't work?
Could you create a new version to issue this problem?
Regards.
Laurent.
Collin Clark Wed, 08/04/2010 - 07:22
We only tried to log from the VRF on routers. I do have a spare 3750X so maybe I'll lab it up and see if it works.
I'm not sure what you mean by this, can you clarify?
r.laurent Wed, 08/04/2010 - 07:28
I wanted to know if Cisco will developp on the Ctalyst 3750 a new version enable to log message in a VRF environnement.
Regards.
Laurent.
Collin Clark Wed, 08/04/2010 - 07:31
That would have to be a feature request that you send up through your local Cisco SE.
