ACS 5.1 - Evaluating Exception Authorization Policy
fschramke
I'm getting the error 'No rule was matched'.
The authentication itself passes; the 'Radius Identity Servers' are sending back the accept.
Tcpdump shows that the ACS is not asking the AD as defined in the compound condition.
What am I missing?
2 Accepted Solutions
jrabinow
Level 7
Level 7
Can you please clarify what you have selected as the result of the identity policy. If you are still using the default defined access services you will see this at the following location:
Access Policies > Access Services > Default Network Access > Identity
In order to use the attributes from AD in the authorization decision Active Directory must be included in the results for the identity policy. This can be done in one of two ways:
- Select the database directly
- Define and select an identity sequence that includes Active Directory
Was just writing that to respond but you got there first while I was in the middle
Interesting use case using some of the more adavnced capabilities
5 Replies 5
jrabinow
Level 7
Level 7
Thanks for getting back to me.
The AD is part of the selected Identity Store.
I'm trying to migrate our our old Steelbelted Radius with a Vasco Plugin to the ACS with a new ActivIdentity OTP Token Server.
So I setup those two as Radius Identity Servers and placed them with the AD in an Identity Store. A reject of the first server will be treated as a user not found, if the second server sends a reject the ACS will treat it as an authentication failed.
I don't want to authenticate against the AD I just want the attribute in the user object as it contains the VPN Group Policy that needs to be applied to the user.
Argh...never mind; found it.
I had to add the AD in the Identity Store Sequence to the 'Additional Attribute Retrieval Search List Group'.
Thanks for the help, put me on the right track.
Yeah...took a while to get all the little pieces clicked together, but now i got the last piece of the puzzle and can run some final tests today and then start migrating some test users.
