VPN Tunneling question
I am trying to set up a site to site vpn tunneling all traffic through the vpn tunnel to the main site.  I have looked at the forum posts many times but apparently too dense to see what is needed.  The tunnel comes up and i can pass traffic across the tunnel for the private lan...but internet traffic does not traverse the tunnel.  I cant help but think it is a nat issue but do not understand why.
Any help will be appreciated.
here is the relevant configs;
remote site: 871 router
crypto isakmp policy 15
encr aes 256
authentication pre-share
group 2
crypto isakmp key ********* address 207.xx.xx.xx
crypto ipsec transform-set esp-aes esp-aes 256 esp-sha-hmac
crypto map vpn 10 ipsec-isakmp
set peer 207.xx.xx.xx
set transform-set esp-aes
match address VPNTRAFFIC1
ip nat inside source list NONAT interface FastEthernet4 overload
ip access-list extended NONAT
  deny   ip any
ip access-list extended VPNTRAFFIC1
permit ip  *if i change this to permit ip any then no traffic passes through the tunnel.
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect MYFW out
ip nat outside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1460
speed 100
no cdp enable
crypto map vpn
HQ site: ASA 5510
sysopt permit ipsec command enabled
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ipsec transform-set esp-aes-sha esp-aes-256 esp-sha-hmac
crypto map outside_map 30 match address outside_30_cryptomap
crypto map outside_map 30 set peer 98.xxx.xxx.xxx
crypto map outside_map 30 set transform-set esp-aes-sha
crypto isakmp nat-traversal  20
crypto isakmp ipsec-over-tcp port 10000
crypto isakmp disconnect-notify
tunnel-group 98.xxx.xxx.xxx type ipsec-l2l
tunnel-group 98.xxx.xxx.xxx ipsec-attributes
pre-shared-key *
nat (inside) 0 access-list inside_nat0_outbound
access-list inside_nat0_outbound extended permit ip any
access-list outside_30_cryptomap extended permit ip any
Jennifer Halim Wed, 08/04/2010 - 08:11
The reason why internet traffic is not working is because you have configured NONAT for traffic from subnet towards everything. To browse the internet, traffic needs to be PATed.
Here is what needs to be configured for the NONAT access-list:
  deny   ip
  permit ip any
Please kindly remove the existing NONAT ACL, and replace it with the above.
Further to that, crypto ACL needs to be as follows:
On router: permit ip
On ASA: access-list outside_30_cryptomap extended permit ip
Hope that helps.
