08-04-2010 08:21 AM - edited 03-16-2019 12:04 AM
We cannot utilize all the buttons on the Sidecars (7915 & 7916) to their maximum capacity due to the 42 buttons limitation on Callmanager.
We are using 7962.
IS this something that can be fixed by installing a device pack/patch?
If not, does anyone know the earliest CUCM version on which it is fixed ?
On CUCM 7.1.2, i found that it supports 54 buttons for 7962.
08-04-2010 08:49 AM
Based on the release notes it appears that it was a limitation on SCCP through version 7.0(2a): http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/7_0_2/cucm-rel_notes-702a.html#wp581689
Starting in 7.1(2) this statement is absent from the release notes which suggests that the SCCP protocol was updated to support the 56 buttons possible.
08-04-2010 08:50 AM
Hi Kumar,
This cannot be changed by any DevPak install/upgrade
Cisco Unified IP Phone Expansion Module 7916 Button Support (SCCP)
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/data_sheet_c78-468673.html
Cisco Unified IP Phone Expansion Module 7915 Button Support (SCCP)
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/data_sheet_c78-468672.html
Cheers!
Rob
08-04-2010 09:08 AM
Thanks a lot to both of you.
08-04-2010 09:20 AM
Hi Kumar,
You are most welcome my friend
Cheers!
Rob
