Adding to an ACL
Answered Question
Aug 4th, 2010
This is already configured
ip access-list standard INCARRIER
permit 10.10.4.0 0.0.0.255
permit 10.10.204.0 0.0.0.255
permit 10.10.33.0 0.0.0.255
and I want to add this
permit 10.10.7.0 0.0.0.255
and I want it to look like this
would I do this
2821#config t
Enter configuration commands, one per line.  End with CNTL/Z.
2821(config)#ip access-list standard INCARRIER
2821(config-std-nacl)#permit 10.10.7.0 0.0.0.255
or would I need to do this
2821#config t
2821(config-std-nacl)#permit 10.10.4.0 0.0.0.255
2821(config-std-nacl)#permit 10.10.204.0 0.0.0.255
2821(config-std-nacl)#permit 10.10.33.0 0.0.0.255
Mike
Correct Answer by Collin Clark about 6 years 6 months ago
Mike-
You can add just the new network, no need to add them all again.
2821#config t
Hope it helps.
Overall Rating: 5 (2 ratings)
Correct Answer
Collin Clark Wed, 08/04/2010 - 08:52
Mike-
2821#config t
Hope it helps.
burleyman Wed, 08/04/2010 - 09:06
Thanks, that is what I thought but wanted to cover my bases.
One more based on that......If I wanted to add in the middle I would need to do this.....correct?
2821#config t
and no need add the last permit
and the result would be
ip access-list standard INPAETEC
Mike
Collin Clark Wed, 08/04/2010 - 09:12
Mike-
Those dang standard ACLs don't have sequence numbers. The order you put them makes no difference in how they show up in the config. If you need to arrange them in a specific order you'll have to use extended ACLs.
