CSS 11503 Moving Circuit/Vlan to GBIC for GB speed
Answered Question
Aug 4th, 2010
Hello
At our Datacenter, we are looking to bring in a GB circuit from the ISP to give us GB throughput across the entire network.  The only sticking point is the CSS.  Right now all connections are made using the Fast Ethernet ports.  Is it possible to turn up a Gig ports on the management card and use it to relocate an already existing circuit/vlan?  Using the GBIC, I want to connect over fiber to a Cisco 3750 switch.  Is this possible?
Correct Answer by yushimaz about 6 years 7 months ago
You can enable gig ports on SCM but user traffic may stop for several tens of seconds.
I confirmed the behavior with my lab devices.
--- interface config on CSS
interface  1/1
  admin-shutdown
  bridge vlan 774
interface  1/2
  admin-shutdown
  bridge vlan 775
interface  2/1
  bridge vlan 774
interface  2/2
  bridge vlan 775
When I enabled (issued no admin-shut) at interface 1/1 and 1/2, bridge forwarding table
was purged and all services went down.
After several tens of seconds, all client and server mac address were listed on bridge
forwarding table and all services went alive. (Console log of my test is attached.)
CSS11503-A# show bridge forwarding
VLAN     MAC Address          Port Number
VLAN774  00-1d-45-26-87-17     2/1
VLAN775  00-0c-29-21-d7-62     2/2
          00-0c-29-2f-15-7b     2/2
          00-1d-45-26-87-18     2/2
          00-0c-29-68-3e-de     2/2
CSS11503-A# show service summary
Service Name                     State     Conn  Weight  Avg   State
                                                         Load  Transitions
sv1                              Alive         0      1     2           34
sv2                              Alive         0      1     2           32
sv3                              Alive         1      1     2           38
CSS11503-A# conf t
CSS11503-A(config)# int 1/1
CSS11503-A(config-if[ 1/1])# no admin-shutdown
CSS11503-A(config-if[ 1/1])# int 1/2
CSS11503-A(config-if[ 1/2])# no admin-shutdown
                                                         Load  Transitions
sv1                              Down          0      1   255           35
sv2                              Down          0      1   255           33
sv3                              Alive         0      1     2           40
VLAN774  00-0c-29-56-32-91     1/1
VLAN775  00-0c-29-21-d7-62     1/2
I mean that you can connect between cat3750 and CSS with GBIC and fiber cable.
However, communication failure may occur during this operation. (Maintenance window
wil be needed.)
Overall Rating: 5 (1 ratings)
Correct Answer
yushimaz Mon, 08/09/2010 - 01:10
  • Cisco Employee,
interface  1/1
  admin-shutdown
  bridge vlan 774
interface  1/2
  admin-shutdown
  bridge vlan 775
interface  2/1
  bridge vlan 774
interface  2/2
  bridge vlan 775
                                                         Load  Transitions
sv1                              Alive         0      1     2           34
sv2                              Alive         0      1     2           32
sv3                              Alive         1      1     2           38
CSS11503-A# conf t
                                                         Load  Transitions
sv1                              Down          0      1   255           35
sv2                              Down          0      1   255           33
sv3                              Alive         0      1     2           40
wil be needed.)
