Basic Rate ISDN problems
Answered Question
Aug 4th, 2010
Hi All, Wondering if someone can spot any issue swith the config below. Basically it's a 2821 with 4 BRI ports controlled via MGCP from callmanger 7.X. I am sure I am right but I need to make sur ethat the TEI negotiation would occur whatever the callmanager config - the ports themselves have registered with CCM.
no aaa new-model
network-clock-participate wic 2
network-clock-participate wic 3
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.114.16.245 10.114.16.254
ip dhcp pool IPT-Phones
   network 10.114.16.0 255.255.255.0
   default-router 10.114.16.251
   option 150 ip 10.112.14.1 10.112.14.2
isdn switch-type basic-net3
voice-card 0
no dspfarm
archive
log config
  hidekeys
interface GigabitEthernet0/0
description Link to switch fa 1/0/7
backup interface GigabitEthernet0/1
ip address 10.114.16.251 255.255.255.0
duplex full
speed 100
description backup Link to switch fa 5/0/1
duplex full
speed 100
standby 0 mac-address 2893.fef8.7100
interface BRI0/2/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
interface BRI0/2/1
no ip address
interface BRI0/3/0
no ip address
interface BRI0/3/1
no ip address
ip default-gateway 10.114.16.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.114.16.254
ip http server
no ip http secure-server
control-plane
voice-port 0/2/0
compand-type a-law
cptone GB
voice-port 0/2/1
compand-type a-law
cptone GB
voice-port 0/3/0
compand-type a-law
cptone GB
voice-port 0/3/1
compand-type a-law
cptone GB
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.112.14.1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.112.14.1
ccm-manager config
mgcp
mgcp call-agent 10.112.14.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode cisco
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
errors from debig ISDN Q921
*Aug  4 14:30:18.015: ISDN BR0/2/0 Q921: User TX -> IDREQ ri=22580 ai=127
*Aug  4 14:30:23.527: ISDN BR0/3/1 Q921: User TX -> IDREQ ri=56181 ai=127
*Aug  4 14:30:23.551: ISDN BR0/3/0 Q921: User TX -> IDREQ ri=37574 ai=127
*Aug  4 14:30:23.551: ISDN BR0/2/1 Q921: User TX -> IDREQ ri=48935 ai=127
*Aug  4 14:30:24.031: ISDN BR0/2/0 Q921: User TX -> IDREQ ri=45464 ai=127
*Aug  4 14:30:25.527: ISDN BR0/3/1 Q921: User TX -> IDREQ ri=51993 ai=127
*Aug  4 14:30:25.551: ISDN BR0/3/0 Q921: User TX -> IDREQ ri=31914 ai=127
*Aug  4 14:30:25.551: ISDN BR0/2/1 Q921: User TX -> IDREQ ri=18251 ai=127
*Aug  4 14:30:26.031: ISDN BR0/2/0 Q921: User TX -> IDREQ ri=48124 ai=127
*Aug  4 14:30:27.527: ISDN BR0/3/1 Q921: User TX -> IDREQ ri=31677 ai=127
*Aug  4 14:30:27.551: ISDN BR0/3/0 Q921: User TX -> IDREQ ri=14222 ai=127
*Aug  4 14:30:27.551: ISDN BR0/2/1 Q921: User TX -> IDREQ ri=45167 ai=127
*Aug  4 14:30:28.031: ISDN BR0/2/0 Q921: User TX -> IDREQ
Correct Answer by Steven Holl about 6 years 6 months ago
I'm assuming that 'sh isdn st' shows L2 not up, right?
Do you know how your provider is provisioned as far as the TEI goes?  Are they doing a dynamic or static TEI?  Half the time, you usually need to add this:
isdn static-tei 0
-Steve
Overall Rating: 5 (1 ratings)
Correct Answer
Steven Holl Wed, 08/04/2010 - 11:09
isdn static-tei 0
-Steve
Paul Austin Wed, 08/04/2010 - 11:31
They would normally be dynamic but I'l give it a go.
Thanks very much
Paul Austin Thu, 08/05/2010 - 11:08
Hi Steve, Yep that was the fix - thanks very much. Afterwards I
remembered I had to do something similar about 10 years ago but forgot about it as we don't do much of that stuff nowadays.
