08-04-2010 09:43 AM - edited 07-03-2021 07:02 PM
Is it possible to upgrade the WCS from 6.0.132.0 to 7.0.164.0. Is it necessary to take the backup of 6.0.132.0 and restore it in 7.0.164.0 or directly we can upgrade from 6.0.132.0 to 7.0.164.0.
The backup from 6.0.132.0 is compatible with 7.0.164.0 or do we hae to upgrade it in to 6.0.181.0.
08-04-2010 09:52 AM
You can go from 6.0.132.0 to 7.0.164.0 as referenced here:
http://www.cisco.com/en/US/docs/wireless/wcs/release/notes/WCS_RN7_0.html
I would recommend the manual upgrade procedure located here:
http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0main.html#wp1087553
08-04-2010 09:55 AM
Just One question,
What about the database compatibility between 6.0.132.0 & 7.0.164.0
Can we restore the backup from 6.0.132.0 to 7.0.164.0 OR do we have to upgarde to 6.0.181.0 first
08-04-2010 09:59 AM
Can we restore the backup from 6.0.132.0 to 7.0.164.0 - yes
do we have to upgarde to 6.0.181.0 first - no
08-04-2010 10:02 AM
thank you boss. i will try it out tomorrow and will let u know.
08-08-2010 01:25 PM
Thanks. I managed to upgrade the WCS to 7.0.164.0.
But now i am facing a strange issue. After the upgrade i cannot track any of the clients.
All the controllers were synchronized with the Location appliance and the synchronize icon is also coming. But out of 22 controllers , the NMSP status is in the inactive state for 21 controllers.
Only one controller is having NMSP active state. Did you come across with such issues.
WLC : 7.0.98.0
WCS : 7.0.164.0
LA:6.0.102.0
Please find the attached screen shot for your reference.
Thanks & Regards
Sreejith R
08-08-2010 02:40 PM
Your LA version needs to be the 6.0.101.0 as per :
Clean up the Location Appliance, SSH to it and follow the steps:
1. Stop the location server. root @ localhost > service locserverd stop Shutting down locserverd: Request server shutdown now... Server shutdown complete.
2. Move the existing database file root @ localhost > mv /opt/locserver/db/linux/server-eng.db /opt/locserver/db/linux/server-eng.db.old or Use the command: rm -rf /opt/locserver/db/linux/server-eng.db
3. Start the location server back. root @ localhost / > service locserverd start Starting locserverd:
4. Run the synchronization job in WCS. Run the Location Server Synchronization job after selecting all the network designs and the controllers form the sync page.
This should resolve your issue.
I suggest you to listen to my webcast:
https://supportforums.cisco.com/community/netpro/ask-the-expert/webcasts
