No ping to inside via VPN connect
nguyenthac86
I configure asa with remote access VPN.
            VLAN 1:
ASA5505(config)# interface VLAN 1
ASA5505(config-if)# nameif inside
            ASA5505(config-if)# security-level 100
ASA5505(config-if)# ip address 100.11.32.251 255.255.255.0
ASA5505(config-if)# no shutdown
            VLAN 2:
ASA5505(config)# interface VLAN 2
ASA5505(config-if)# nameif outside
ASA5505(config-if)# security-level 0
ASA5505(config-if)# ip address 192.168.1.1 255.255.255.0
Allow Ethernet 0/0 access VLAN 2 (outside)
ASA5505(config)# interface Ethernet 0/0
ASA5505(config-if)# switchport mode access
ASA5505(config-if)# switchport access VLAN 2
Allow Ethernet 0/1-7  access VLAN 1 (inside)
ASA5505(config)# interface Ethernet 0/1
ASA5505(config-if)# switchport access VLAN 1
            ASA5505(config)# route outside 0.0.0.0 0.0.0.0 192.168.1.2 1
ASA5505(config)# isakmp policy 2
ASA5505(config-isakmp-policy)# authentication pre-share
ASA5505(config-isakmp-policy)# encryption des
ASA5505(config-isakmp-policy)# hash md5
ASA5505(config-isakmp-policy)# exit
Enable isakmp on interface outside
ASA5505(config)#crypto isakmp identity address
ASA5505(config)#crypto isakmp enable outside
Creat IP pool with name VPNclient and have IP range : 192.168.168.1-192.168.168.254/24
ASA5505(config)# ip local pool VPNclient 192.168.168.1-
          192.168.168.254 mask 255.255.255.0
Creat username/password for VPN client that used for authentication on Local
ASA5505(config)# username xxxxx password xxxxxxx privilege 15
Creat  transform-set with name myset
ASA5505(config)# crypto ipsec transform-set myset esp-des esp-md5-hmac
Select tunnel-group type/attributes
ASA5505(config)# tunnel-group IM type ipsec-ra
ASA5505(config)# tunnel-group IM general-attributes
ASA5505(config-tunnel-general)# address-pool VPNclient
ASA5505(config-tunnel-general)# exit
Creat user/password for group authentication
ASA5505(config)# tunnel-group IM ipsec-attributes
ASA5505(config-tunnel-ipsec)# pre-shared-key xxxxxxx
Creat access-list for interesting traffic
ASA5505(config)# access-list Client permit ip 100.11.32.0  255.255.255.0 192.168.168.0 255.255.255.0
ASA5505(config)# nat (inside) 0 access-list Client
Creat dynamic map
ASA5505(config)# crypto dynamic-map dyn1 1 set transform-set myset
ASA5505(config)# crypto dynamic-map dyn1 1 set reverse-route
Creat crypto map and assign it on outside interface
ASA5505(config)# crypto map mymap 10 ipsec-isakmp dynamic dyn1
ASA5505(config)# crypto map mymap interface outside
But when i connect VPN to ASA , i can't ping to my server in inside. my server have got ip address 110.11.32.20/ (not set default gateway).
Please, help me!
11 Replies 11
Jitendriya Athavale
check no nat or nat exemption
your nat 0 access-list should have acl permit from internal network to pool ip's
enter this command
sysopt connection permit-vpn
crypto isa nat-t
i am not sure whether you want it this way but you have your private ip in less secure zone and public ip in the more secure zone
enter this commad "management-access"and check if you can ping the inside interface ip
if all this doesnt work
and paste the output of the following
show cypto ipsec sa
Thanks.
I can ping to one inside. i still can't ping to the other ip inside.
when i show running configure. I see "icmp unreachable rate-limit 1 burst-size 1". I configured acl permit ip from inside to pool's ip.
how to do??
check if you have routes to reach 110.11.32.20 on asa
check on the other layer 3 devices that you have in between the asa and 110.11.32.20 if they have routes to get to the vpn pool ip's
please paste sh cry ips sa
: Saved
ASA Version 8.2(1)
hostname ciscoasa
domain-name aaaaa.com
enable password xxxxxx
passwd xxxxx encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.11.32.251 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 110.35.74.6 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list client extended permit ip 10.11.32.0 255.255.255.0 192.168.168.0 255.255.255.0
pager lines 24
mtu inside 1500
mtu outside 1500
ip local pool VPNclient 192.168.168.1-192.168.168.254 mask 255.255.255.0
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list client
route outside 0.0.0.0 0.0.0.0 110.35.74.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto isakmp policy 2
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
telnet timeout 5
ssh 10.11.32.20 255.255.255.255 inside
ssh timeout 30
ssh version 2
console timeout 0
management-access inside
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username cccccc password xxxxxx encrypted privilege 15
tunnel-group IM type remote-access
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:47981e187a1fdfa8206d5aa14a5de0ad
: end
Yes,
This is my show run
: Saved
ASA Version 8.2(1)
hostname ciscoasa
enable password xxxxx encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
encryption des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 30
ssh version 2
console timeout 0
username thac  password xxxxx encrypted privilege 15
pre-shared-key *
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
: end
this is different from wht you had posted earlier
sorry,
i post show cry ipsec sa
interface: outside
    Crypto map tag: dyn1, seq num: 1, local addr: 110.35.74.6
      local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.168.1/255.255.255.255/0/0)
      current_peer: 110.35.74.5, username: thac86
      dynamic allocated peer ip: 192.168.168.1
      #pkts encaps: 4, #pkts encrypt: 4, #pkts digest: 4
      #pkts decaps: 76, #pkts decrypt: 76, #pkts verify: 76
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 4, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 110.35.74.6/10000, remote crypto endpt.: 110.35.74.5/4120
      path mtu 1500, ipsec overhead 94, media mtu 1500
      current outbound spi: DFEA853D
    inbound esp sas:
      spi: 0xB5FFB642 (3053434434)
         transform: esp-des esp-md5-hmac no compression
         in use settings ={RA, Tunnel,  TCP-Encaps, }
         slot: 0, conn_id: 40960, crypto-map: dyn1
         sa timing: remaining key lifetime (sec): 28751
         IV size: 8 bytes
         replay detection support: Y
         Anti replay bitmap:
          0xFFFFFFFF 0xFFFFFFFF
    outbound esp sas:
      spi: 0xDFEA853D (3756688701)
         sa timing: remaining key lifetime (sec): 28749
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
hi thac,
can you please confirm which is the correct config as you have pasted 2 diff config's
Sorry for inconvenience
this is the correct configuration.
: Saved
ASA Version 8.2(1)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
encryption des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 30
ssh version 2
console timeout 0
pre-shared-key *
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
: end
I am assuming that you are using remote vpn clients. I don't see a group
policy configured for the vpn clients.
group-policy ipsec-attributes
pre-shared-key *
Hope this helps.
NT
i think the tunnel is fine bcoz we see spi's we can ping the inside ip with management-access inside
can you apply some captures and see
capture capin interface inside match ip host host
after this ping the internal ip
sh cap capin
see if the traffic is leaving the firewall and coming back
because i see decaps but no encaps
this mean check natting and routing
