CRS-1 adds MSC
Giuseppe Larosa Wed, 08/04/2010 - 12:27
Hello Costail,
>> Use the Status LED, located on the MSC faceplate, to verify the correct installation of the MSC:
When the MSC is properly installed, the Status LED turns green. If this LED is off, verify that the MSC is installed correctly.
If a failure occurs during the board boot sequence, the two four-digit alphanumeric LED displays indicate the current boot phase to assist you in debugging the board failure.
I agree you should be fine if you see the LED becoming steady green
to be noted: in a recent thread has been pointed out that if we install an empty MSC with no SPA, the system does not start IOS XR on it as there is no need to run IOS XR if no external interfaces are available.
Hope to help
