Can I run different versions of VTP on two switches?
Answered Question
Aug 4th, 2010
I need some assistance to understand about the changes in the network if I deploy/connect a new switch (VTP mode: client) to a core switch which is running in a vtp server mode in production network. To my knowledge configuration revison number on new switch which is in client mode should be less than the revision number of the server, as its seen in both switches as shown but I am stuck here by seeing the version numbers on both sides are different. Can anyone please let me know or guide me or send some good link for deploying the new switch in production network or provide me some prerequisites for deploying the new switch. Below are the VTP status details of both server and client.
CORE#sh vtp status
VTP Version capable             : 1 to 3
VTP version running               : 2
VTP Domain Name                : engrlab
VTP Pruning Mode                 : Disabled
VTP Traps Generation             : Enabled
Device ID                                : 001b.d587.aac0
Configuration last modified by 192.168.30.2 at 2-21-10 00:23:28
Local updater ID is 192.168.30.2 on interface Vl30 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                        : Server
Maximum VLANs supported locally    : 1005
Number of existing VLANs                 : 25
Configuration Revision                        : 17
MD5 digest                                       : 0x02 0x30 0xA3 0xE7 0x50 0x2B 0x5B 0x24
                                                          0xD8 0x25 0x92 0x89 0x25 0xF0 0xDD 0x91
NEWSWITCH#sh vtp status
VTP version running                  : 1
VTP Traps Generation               : Disabled
Device ID                                  : 9caf.cac5.ef80
Configuration last modified by 0.0.0.0 at 3-2-93 05:01:49
Feature VLAN:
VTP Operating Mode                        : Client
Maximum VLANs supported locally   : 255
Number of existing VLANs                : 6
MD5 digest                                      : 0xA2 0xC8 0x2C 0x5E 0xEA 0xD2 0x0B 0x97
                                                         0x12 0xB4 0xD7 0x0F 0x97 0xC4 0xC1 0x36
Correct Answer by Sebastian Helmer about 6 years 11 months ago
Hi Habeeb,
first you should follow the guide line from JayaKrishna to allow vtp communication.
What I can say to your question is, that a client can overwrite the vtp setting if the revision number is higher than the server.
To Do's:
1. make sure the you are runnunig as client, if you want that. Server is also possible of course.
2. the revision number is the key and must be lower than the current in the network, otherwise the new switch will overwrite the vtp configuration. Thats mostly bad
regards,
Sebastian
Overall Rating: 5 (1 ratings)
habeebuddin786 Wed, 08/04/2010 - 11:45
Thanks for your quick response.
One more quick question like, Is it safe to connect this new switch in client mode?
Habeeb
Correct Answer
Sebastian Helmer Wed, 08/04/2010 - 11:54
  • Silver, 250 points or more
Hi Habeeb,
To Do's:
regards,
Sebastian
habeebuddin786 Fri, 08/06/2010 - 13:59
Hi Jayakrishna, sebastian,
Thanks for your help and suggestions. I have deployed the new switches successfully in the production network successfully.
Cheers!!!
Habeeb
Related Content
