Cisco ASA 5510 Security Plus 5th port???
ryabutler
The Cisco ASA 5510 has 4 ethernet ports, a console port, AUX port, and a management port.
With the Security Plus for the ASA 5510 you can use 2 ports for 10/100/100 and 3 ports for 10/100 (or 5 ports for 10/100).
Where is this fifth port coming from exactly?
What 2 ports are GE?
Thank you!
-rya
Sorry I missed your other quesiton. In older code versions, the management port is the 5th port when you use the 'no management-only' command. In newer versions, this just becomes the 5th interface by default.
-Mike
mirober2
The interfaces are described at the link below. 0/0 and 0/1 will be your gigabit interfaces.
http://www.cisco.com/en/US/docs/security/asa/asa82/license/license82.html
Hope that helps.
-Mike
-Mike
Thank you!  I was having problems trying to locate this info on the Cisco ASA pages.  I was thinking it had to be the management port, but wanted to be 100% sure.
Thanks again!
-rya
