BLF Import/Export Issue
Aug 4th, 2010
I'm trying to find the easiest way to import BLF speed dials for large number of phones .  It doesnt appear that the BAT file has an option for BLFs.
I have began looking at the Import/Export feature of UCM to perform this function.   Unfortunately every time I try to import a csv with a BLF i get the error:
SEP001122334455 XXXX is not a valid BLF Speed Dial
The annoying thing is that if I create a phone in UCM, then do an export of phone information, i can see the exact CSV format UCM is using.   If i take that same exact file and try to import it i still get the above error.
Has anyone run into this?  Is there an easy fix?   Is there any way to mass import BLFs?
I am currently running UCM 7.1(5)
Wes Sisk Thu, 08/05/2010 - 06:50
  • Cisco Employee,
sounds very similar to
CSCsy59400    Insert Phones doesn't allow DN to be BLF DN
Does the workaround work for you?
Symptom:
Conditions:
Follow the steps mentioned in Defect Description
Workaround:
Don't give the BLF DN same as DN. First Insert Phones with DN and then add BLF DN using another insert job with override option.
mhurley131 Thu, 08/05/2010 - 11:56
I believe I tried this, but not sure.  I imported phones with all fields except for the BLF fields.   I then ran it again with all fields including the BLF fields with the override box checked.
I can try and run it with the just Device name and BLF fields and see what that will even run.
Where did you get the bug information from?
