PIX trap setup
Aug 4th, 2010
PIX 515 using v7.2
I want to send snmp trap \ syslog via inside interface to syslog server
I have this configured:
snmp-server host inside 10.10.0.3 community Bleek
snmp-server enable traps syslog
no snmp-server enable
does it make sense?
Magnus Mortensen Wed, 08/04/2010 - 20:59
Ofir,
To send normal syslogs (udp port 514) to a server....
logging on
logging trap 7             <<<<< Change the number to match the level at which you wish to log... 7 Is debug level...
logging host inside 10.10.0.3
To send SNMP traps to a snmp server....
snmp-server enable traps all
To send SYSLOG messages inside SNMP traps...
logging on
logging history 7             <<<<< Change the number to match the level at which you wish to log... 7 Is debug level...
Hope that helps...
- Magnus
