SRW2048 Fiber Run to HP ProCurve 2524 via MGBSX1 Not functioning
Aug 4th, 2010
All,
I have a customer with a single Cisco SRW2048 switch that has been installed at the network core and is due to replace two aging HP ProCurve 2524 Switches. Previously, the HP Procurves were linked via Fiber to similar HP ProCurve 2524's in a network closet on the opposite side of the building. The Fiber running through the walls is terminated on both sides with a generic / fully functional Fiber switch that use ST Connectors to output the fiber.
On both ends, currently, a ST -> SC MultiMode Fiber is connected from the fiber switch to a HP ProCurve 100-FX SC Transceiver (J4853A: http://h10010.www1.hp.com/wwpc/ie/en/sm/WF06c/A1-329290-64274-64484-64484-51105-22212.html). This setup works 100% right now, however, they do not want to keep the old switch around (inside the core) simply to act as a transceiver for the fiber run.
They purchased a MGBSX1 and a ST -> LC MMF cable and can not seem to get it functional. I saw this thread: http://homecommunity.cisco.com/t5/Switches/connecting-two-SRW2048-switches-over-multimode-fiber/m-p/270381 and attempted shutting off auto negociation (locking it down at 100MB) and it did not bring the interface up (Interface is always down).
I just saw this thread tonight: https://supportforums.cisco.com/thread/2012252 Can anyone confirm that the MGBSX1 can not clock down to 100MB to pair with the 100-FX transciever they have?
If it CAN, has anyone done such a project before / can give me some insight on this matter?
Thanks in advance!
David Hornstein Thu, 08/05/2010 - 06:29
  • Gold, 750 points or more
Hi Jonathan,
The MGBSX1  will not clock at 100FX speeds sorry, and I'm guessing that if you want to run 100FX the distances between the switches are larger than 200meters.
The MFEFX1 (100FX)  or MFELX1  (100LX)  modules are not any help to you they support the following products;
Compadability for MFEFX1 and MFELX1
Switch   Model Number MFEBX1/MFEFX1/MFELX1
SR224G Not supported
SR2024C Not supported
SR2024 Not supported
SPS208G1.0.2
SPS224G41.0.2
SPS20241.0.2
SRW208G1.0.3
SRW208L1.0.3
SRW208P1.0.3
SRW208MP1.0.3
SRW20081.0.3
SRW2008P1.0.3
SRW2008MP1.0.3
SRW224G41.2.2*
SRW248G41.2.2*
SRW224G4P1.0.1
SRW248G4P 1.0.1
SRW2024P1.0.3
SRW2016Not supported
SRW2024Not supported
SRW2048Not supported
SRW224PNot supported
SFE2000Not supported
SFE2000PNot supported
SGE2000Not supported
SGE2000PNot supported
SFE2010 2.0.1.80
SGE2010 2.0.1.75
SFE2010P2.0.1.80
SGE2010P2.0.1.75
SLM224G2-CN1.0.2*
SLM224G1.0.1
SLM248G1.0.1
SLM224P1.0.1
SLM248Pb 1.0.1
SLM20241.0.1
SLM20481.0.1
SLM224G4S1.0.2
SLM224G4PS1.0.2
SLM248G4S1.0.2
SLM248G4PS1.0.2
* SFP port requires   manual configuration for the 100M SFP  .
But I have attached the install guide for the 100meg fiber  modules as a refererence.
My apologies for this situation, please unicast me with contact details.
regards David .
Related Content
