IP SLA average jitter value calculation formula
Aug 5th, 2010
Hi there:)
Cisco IP SLA has a feature Path-jitter.
router#show ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
Type of operation: udp-jitter
        Latest RTT: 44 milliseconds
Latest operation start time: 11:40:36.392 MSD Thu Aug 5 2010
Latest operation return code: OK
RTT Values:
        Number Of RTT: 100              RTT Min/Avg/Max: 19/44/72 milliseconds
Latency one-way time:
        Number of Latency one-way Samples: 100
        Source to Destination Latency one way Min/Avg/Max: 5/30/58 milliseconds
        Destination to Source Latency one way Min/Avg/Max: 13/14/21 milliseconds
Jitter Time:
        Number of SD Jitter Samples: 99
        Number of DS Jitter Samples: 99
        Source to Destination Jitter Min/Avg/Max: 0/16/45 milliseconds
        Destination to Source Jitter Min/Avg/Max: 0/2/8 milliseconds
Packet Loss Values:
        Loss Source to Destination: 0           Loss Destination to Source: 0
        Out Of Sequence: 0      Tail Drop: 0
        Packet Late Arrival: 0  Packet Skipped: 0
Voice Score Values:
        Calculated Planning Impairment Factor (ICPIF): 0
        Mean Opinion Score (MOS): 0
Number of successes: 14
Number of failures: 0
Operation time to live: Forever
There is no Average two way jitter value but I can get it via SNMP.
SNMP OID is:
1.3.6.1.4.1.9.9.42.1.5.2.1.46 - rttMonLatestJitterOperAvgJitter
Avg of Positive and Negative Jitter in SD & DS direction
How does this value calculate?
What formula has been used in IOS for this calculation?
I've tried to calculate this value by myself with the method from
RFC 3550 and I get different result than IOS gets me via
1.3.6.1.4.1.9.9.42.1.5.2.1.46 OID.
Can anyone shed some light on this?
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 08/05/2010 - 19:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is calculated using the following formula:
rttMonLatestJitterOperAvgJitter = ceil(jitterSum / jitterNum)
Where:
jitterSum = sumOfPositiveDS + sumOfNegativeDS + sumOfPositiveSD + sumOfNegativeSD
jitterNum = "Number of DS jitter samples" + "Number of SD jitter samples"
Ignacio Michelena Wed, 03/25/2015 - 05:50
What if I need to get Jitter values from my network but I am not able to use IP SLA features. Is there a recommended way to calculate it from ping tests?
Thanks!
Related Content
