Changing the MTU value on a gig port on a Cisco 7609
Answered Question
Hi All
Just wondering if it is possibel to set the MTU value on a specific gig port on a Cisco 7609 and if so what command would I use please?
Best Regards,
Michael
Correct Answer by u1kumar2002 about 6 years 9 months ago
     To configure MTU :
7609(config)#int gigabitEthernet 1/1
7609(config-if)#mtu ?
  <1500-9216>  MTU size in bytes
7609(config-if)#mtu 921
7609#show interfaces gigabitEthernet 1/1
GigabitEthernet1/1 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0007.0d0e.640a (bia 0007.0d0e.640a)
  MTU 9216 bytes, BW 1000000 Kbit, DLY 10 usec,
For more information Visit : http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
Uttam
Overall Rating: 5 (1 ratings)
Correct Answer
u1kumar2002 Thu, 08/05/2010 - 03:17
     To configure MTU :
Uttam
Hi There
Cheers for the quick response. I had just found that
The only time up to now I changed the MTU value was on the WAN interface on a Cisco 877 router adn that was done with the "ip tcp adjust" command so I was checking under "ip" on the interface.
Once I just used Cisco help under the interface I spotted the "mtu" command, doh
Best Regards & Thanks again,
Michael
