Dropping TCP Segment
Aug 5th, 2010
Hi, when I downloading file from internet I'm getting error in log file:
Dropping TCP Segment seq:1795892888 1300 bytes is out-of-order, expected seq:1795841228, Reason: TCP reassembly queue overflow -session 192.168.0.125:4142 to 92.123.72.98:80 on zone-pair ccp-zp-in-out cla
Colud you tell me how to setup rule in firewall to not getting block whlie dowlnoading? my router is 892 cisco.
Jitendriya Athavale Thu, 08/05/2010 - 06:30
  • Cisco Employee,
i think you are using a firewall on the router
if so then try removing inspect http and see if you get the same error
if its a zone based firewall you will need to go to 15.0 code i guess
zycha1983 Thu, 08/05/2010 - 06:54
Yup, I have firewall configured.
Under ccp-inspect (in-zone to out-zone) I have line
any (source) any (destination) http (service) inspect (action)
You think I should delete that line?
Im using GUI interface cause I'm not good at command prompt yet.
Jitendriya Athavale Thu, 08/05/2010 - 07:37
  • Cisco Employee,
yeah for zone based firewall the out of order buffer support was introduced in only 15.0 code. are you running 15.0 code
