Port forwarding [Solved]
p.maillot
Hello All,
I have the following problem.
I need to forward a specific range for udp port (32000 to 32999) to a local ip adress.
I actually to do that, I use this command
ip nat inside source static udp 192.168.40.1 32000 interface Ethernet0 32000
ip nat inside source static udp 192.168.40.1 32001 interface Ethernet0 32001
ip nat inside source static udp 192.168.40.1 32002 interface Ethernet0 32002
it's not possible to forward a range for port?
I used a nat configuration for internet access.
ip nat pool POOL-NAT x.x.x.x x.x.x.x netmask 255.255.255.0
ip nat inside source list 100 interface Ethernet0 overload
Have this config in your NAT process
ip nat inside destination list xxx pool inside
access-list xxx permit udp any any range xxxxx xxxxx
Best Regards,
Christopher
5 Replies 5
vragotha
Level 3
Level 3
   This feature is not currently supported. The only way to do it currently is to manually add static nat entries for each port. CSCsk86712 is an enhancement bug filed for this
Best Regards,
Christopher
All works perfectly now.
Thank you Christopher for your assistance........
Hello, please could you check in what IOS version this enhacement was included already ?
tahnks
Version 12.3(26)
