SSL VPN - Web Portal Customization
Aug 5th, 2010
When I connect to a web bookmark that I have created, 4 icons appear in the top right hand corner.
These are the 'Move to other side', 'Go to address', 'Home page' and 'Logout' buttons.
If I select 'Move to other side' they move to the top left hand corner, is there anyway I can configure these to automatically appear on the left when I connect?
I've had a look at the customization option, but there is nothing shown which relates to this.
Kind Regards
Terry
