Interface dot11radio1 is reset down and does not works.
Aug 5th, 2010
I configured ssid and is a nonroot equipement and whwn I do sh ip inter brief the status interface dot11radio1 is reset and down and does not assosciate with the root AP
This is the configuration:
ip ssh version 1
dot11 ssid fbpinto
authentication open
authentication shared
authentication key-management wpa
wpa-psk ascii 7 051C160E315F450F1B151E1C1F03
dot11 network-map
power inline negotiation prestandard source
username Cisco password cisco
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
station-role root bridge
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
no sh
interface Dot11Radio1
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid fbpinto
antenna gain 9
power client local
station-role non-root bridge
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
no sh
interface BVI1
ip address 172.27.119.10 255.255.255.128
no ip route-cache
no sh
ip default-gateway 172.27.119.1
dancampb Thu, 08/05/2010 - 06:47
  • Cisco Employee,
It is the expected behavior for the radio interface to be down on a non-root until it associates to a root bridge.  It looks like you are missing the "infratructure-ssid" command under the SSID.  This needs to be on both bridges for them to be able to associate.
a.serrano Fri, 08/06/2010 - 02:42
Thanks very much!
Then untilk the noonroot is not associate the interface radio remanis in  restet status protol down ¿is it?
My problem is that this Brigge  working fine for a year ago but  one day fails and I replace the bridge  but the interface radio remain in status reset  too¿can be that the extenal antenna is broken? and therfore no signal received by the interface and can not associate with root for it?
I try to put boths brigge close and test if interface radio is up and works fine .If works like this I think that is a problem with the extrenal anntena ( dipolo)
regards
Related Content
