Identities - No Authentication for user agent
Answered Question
I am getting problem pops up now and then from developers because they are using different applications to check, update, and code for the web base application in house.  To by pass that, the no authenticaton identities is created and defined in user agent to exclude certain apps like, iTunes, Java, Eclipse, and ect...I just wonder if there is a parameters that put in as a wild card and does not matter what application the developers group install it will work without specified in the user agent field.
Thank you
Correct Answer by edadios about 6 years 11 months ago
When you say deveoloper group, are you using an authentication server NTLM?
Maybe you should instead configure a specific identity for the devloper group to bypass, instead of having another identity for no authentication and based on user agent.
Sorry if I otheerwise misunderstand the question, maybe screen capture of the configured identities, and the access logs for failure will help in understanding.
Overall Rating: 5 (1 ratings)
Correct Answer
edadios Thu, 08/05/2010 - 17:10
  • Silver, 250 points or more
edadios Mon, 08/09/2010 - 17:18
No Problem. I am happy to be of help to you.
