DFM Bulk Unmanage
Aug 5th, 2010
So I have roughly 1200 1811 and 200 1841 routers with similar configurations that I want to import into DFM.  I only have a couple interfaces on each router that I want to manage, but when I import a router there are quiet a few interfaces I manually unmange.
Problem I am having is that the bulk export/import scripts only show the ifindex number with no description.  If all these router used the same index for each interface it would be easy, but they don't.  Is there a way to export the interfaces with description (i.e. kind of like a detailed device view) ?  Or even better pre-manage/unmanage these when the device is originally imported?
Thanks in advance for any ideas I can work off of.
--Rob
Joe Clarke Sat, 08/07/2010 - 10:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, the scripts are hardcoded to export only the object name (for interfaces that is the device name and ifIndex).  The export file must be in a specific format so that the import works correctly.
There is no way to change the default management state.  By default, all interfaces will be managed.
