NTP settings when configuring IPS offline
Aug 5th, 2010
Hi all,
I am trying to configure several IPS units (SSM-20, SSM-40, IPS 4260) before sending them to their physical locations.
The problem is that when I configure the NTP server, the IPS tries to contact the server I've configured. However the IPS is offline and so it obviously fails...
IDS-C7-1(config-hos)# ntp-option enabled-ntp-unauthenticated
IDS-C7-1(config-hos-ena)# ntp-server
IDS-C7-1(config-hos-ena)# exit
IDS-C7-1(config-hos)# exit
Apply Changes?[yes]: yes
Warning: DNS or HTTP proxy is required for global correlation inspection and reputation filtering, but no DNS or proxy servers are defined.
Error: Cannot connect to NTP server or NTP server is not running
The configuration changes failed validation, no changes were applied.
Would you like to return to edit mode to correct the errors? [yes]: no
No changes were made to the configuration.
Is there a way to prevent the IPS from reaching the server, so the configuration is still applied...?
terrygwazdosky Fri, 08/06/2010 - 11:14
You might be able to edit the config manually on your PC and then upload it to the sensor.  I don't have a sensor that isn't in production so I can't test it out.
jacques_henry696 Mon, 08/09/2010 - 02:13
Do you mean using a modified conf file that I would send using the copy command ? (e.g. copy scp:[email protected]//configuration/cfg  current-config )
