2950 DSCP/QOS behavior
Answered Question
Aug 5th, 2010
We have some 2960s in our environment, and we have the switchport and trunk ports configured with
mls qos trust cos
That works fine, and DSCP tags are being passed as-is.
However we had the same command issued on our 2950s, and DSCP was being rewritten/stripped.  I found this document http://www.cisco.com/en/US/tech/tk389/tk813/technologies_q_and_a_item09186a00804976d3.shtml#qa10
Based on that doc I changed it to mls qos trust cos pass-through dscp and the tags are now being passed as-is.
My question is, is the 2950 actually prioritizing packets (honoring DSCP) or is it just passing the tags?
Bill
Correct Answer by Collin Clark about 6 years 7 months ago
It has been a long time since I've worked with the 2950's and I don't remember which is the priority queue. I would assume 4. Here is a link to the SRND for QoS. It's an excellent guide and the official Cisco QoS training class uses this as the guide book.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html
Overall Rating: 4.5 (2 ratings)
Collin Clark Thu, 08/05/2010 - 08:19
  • Purple, 4500 points or more
Bill,
You can configure it to. Take a look at the link you provided and go down two questions, you should find your answer.
Q. What kind of output scheduling do the Catalyst 2950 series switches provide?
billmatthews Fri, 08/06/2010 - 12:42
Thanks Colin.  +5
I read that question, and it certainly seems to provide the answer, but I was wondering if I could get more clarification on what these commands do? Is each wrr-queue creating a forwarding queue?  And then cos-map 4 5 is for expedited forwarding?  Our ISP said to just make sure that we have an expedited forwarding queue setup.   We just used auto qos voip and it set this up:
wrr-queue bandwidth 10 20 70 1
wrr-queue cos-map 1 0 1
wrr-queue cos-map 2 2 4
wrr-queue cos-map 3 3 6 7
wrr-queue cos-map 4 5
mls qos map cos-dscp 0 8 16 26 32 46 48 56
Assuming our voice is being marked as cos 4, does that give us what we need?
Please point me to some intro cos reading if that would be easier.  Thanks
Correct Answer
Collin Clark Mon, 08/09/2010 - 06:16
Kristoff.mace Wed, 02/23/2011 - 10:22
To define a strict priority queue on 2950 (expedite queue) you have to configure this:
wrr-queue bandwitch 10 20 70 0
0 means that queue 4 is an expedite queue.
Be carreful with the version (SI or EI) of the 2950.
Regards.
Related Content
