i have a problem with soho 79
Aug 5th, 2010
tried to make this configuration
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
    2. Use these terminal settings:
    3. 9600 baud rate
    • No parity
    • 8 data bits
    • 1 stop bit
    • No flow control
    1. Refer to these documents for information on how to cable and connect a terminal to the console port or the AUX port:
    2. Cabling Guide for Console and AUX Ports
    1. If you can access the router, type show version at the prompt, and record the configuration register setting. See Example of Password Recovery Procedure in order to view the output of a show version command
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    1. Use the power switch in order to turn off the router, and then turn the router back on.
    2. Important Notes:
    3. In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
    • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    1. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    2. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    3. Type reset at the rommon 2> prompt.
       end begun to write characters
    Îó¨ÖÊ®ûKÈÏÖ
    ½9N÷ÖC¼ÞCèýýýýýýýýüýüýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýØ
           Ìz¨ÌGF
    £Fv­VÔ        È^
    võ»B«§½¨ÎGFFÎÖV            ÌϨÎΫFÌ                       ÎÈV1ÍÌ     üeÞ)!S/¡G£Vþ«µfÎ'Ì9GFϾÏÈî³Íõͽ£Ý·åGÏíBn«7þ«5õÍý®Ýí¨ë­V½¨N¨ÎF½£F)víÍ´
    £F  ÎÈVE»«f£fî³                                      +©§)-18VÝ;õ³³BÜÎ
    VíͨÍM2                U©eÏ(»j£µªB«ÍÍ(ê¿©VÝ©=ÆýîBÜ×VÈ
    v         V£»b¶§Vv'F¡ëÍ
        V³»bV¡                                                      ìÝ¡æVîFÈ«-Ë©§NNfÍHv»£ÍÍvÍèÍÍÿÝ1(.¨«¡/¥©§)«§NB!!a!¡VÞ;õ·³uB!!!!!«)?õ=ÝÎB!!!!!;
                                           B䨫5§V7®V¶3B
                     bo)µ5Ñ/©¯«-%?ÏÈVíV£ÝVv
               ³ÎîÝíìV
    ÊʸFÊËj«o31ݳYHøÌÍ(bV!7¤/ÖD®Ýí¨«Vv         V
    í;                         w£V££õ«³ÍõvÝ9Ëݳ
    ûõvÌïBWݳ¿í³³Oï½ïõW»ÏMHR
    f¨£oFÍI¸VG
    îv
    it is broken???????????
    wat ken y do
    vragotha Thu, 08/05/2010 - 08:54
    • Silver, 250 points or more
          Try changing the baud rate on your hyperterm or whichever terminal emulation you use. Try different options available and see if you can console in.
    vragotha Thu, 08/05/2010 - 12:26
    With Putty, the option to change baud rates is under Connection > Serial -> Speed
    Try with the following speeds
    2400
    4800
    9600
    19200
    38400
    57600
    115200
    vragotha Thu, 08/05/2010 - 13:23
    Glad it worked. Once you are in the device, you can change the speed back to 9600
    line con 0
    speed 9600
    wr mem
