How to connect a voice appliance with CUCMBE?
Aug 5th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
Hi.
I have a voice infrastructure with CUCMBE and C2821 as a voice gateway.
I have a HS Satellite Modem with a voice appliance.
I need to connect the voice appliance to IP telephony network using a call manager extension. i configure this:
1)      Created the extension on the call manager. 3333
2)      Created a dial peer on the C2821 to HS satellite Modem. The same extension 3333.
3)      Create dial peer on the C2821 to call manager. The same extension 3333.
4)      The HN satellite modem connects to C2821 as the voice gateway.
5)      Created a route patter on the call manager to the C2821 as voice gateway for this extension.
The configuration is not function
Jaime Valencia Thu, 08/05/2010 - 12:00
  • Cisco Employee,
  • Hall of Fame,
    2011
Have you tried setting another DN for the otbound?:
)   Created a dial peer on the C2821 to HS satellite Modem. The extension 4444.
5)  Created a route pattern (4444) on the call manager to the C2821.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
