C2960_POE - bad mask /24 on Int VLAN1
Answered Question
Aug 5th, 2010
Greetings,
(Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(44)SE6)
I'm attempting to configure the IP address on int VLAN1 to 192.168.3.0 255.255.255.0 and keep getting:
Bad mask /24 for address 192.168.3.0
I've even tried adding "ip subnet-zero" to the config. but it doesn't make any difference.
It will accept other addresses:  example:  172.18.1.1 255.255.255.0 works fine.
Thanks.
Correct Answer by Jon Marshall about 6 years 6 months ago
iholdings wrote:
Greetings,
Thanks.
192.168.3.0 is the network number. You can't use that. You can use 192.168.3.1 -> 192.168.3.254 with 192.168.3.255 being the broadcast address.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 08/05/2010 - 12:42
iholdings wrote:
Greetings,
Thanks.
Jon
iholdings Thu, 08/05/2010 - 12:50
I believe I came to the same conclusion just as you
were typing your reply.
I can't even use the 'I'm a noob' as an excuse.
Thanks for your prompt reply.  All set.
