Pronounce minute or minutes?
Aug 5th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hey all,
I'm trying to get the system to pronounce the word minute or minutes during expected hold time.
Case in point.   If expected hold time i would like the system to say 1 minute vrs 1 minutes or just 1.
if expected hold time is 2 or more minutes i would like the system to say 2 minutes or 3 minutes or X (where x is the number).
can this be done?
Overall Rating: 5 (1 ratings)
rbblue234 Fri, 08/06/2010 - 05:09
The problem here is that I have no minute.wav or minutes.wav file.
My goal here is to get the system to say 1 minute or 2 minutes in the same voice.
rbblue234 Fri, 08/06/2010 - 06:09
Hrm...  I found the .wav files i needed.
c:\Program Files\wfavvid\Prompts\system\G711_ULAW\en_US\gen\time
Anthony Holloway Fri, 08/06/2010 - 07:34
  • Purple, 4500 points or more
For the sake of the people searching the forum, and who don't know how to use those prompts in a script:
The language folder portion is implied by the language of the contact.
Play Prompt(--Triggering Contact--, sp[gen\time\minutes])
