Uncheck Connect on start-up for Anyconnect web install
Aug 5th, 2010
I an using the Anyconect web install.  It works fine but when it's installed, the Connect on start-up is automaticlly check in the preferences.  How do I disable that from being checked by the install??
ASA 8.2(2)
ASDM 6.3(5)
Anyconnect 2.5.0217
Thanks...
Robert Salazar Thu, 08/05/2010 - 13:53
  • Cisco Employee,
This is the default setting for anyconnect.
To override this you'll need to create/modify the xml profile used in their group-policy.
The default setting in the profile is :
true
When you modify the profile you can set it to false:
false
This controls AnyConnect client behavior when started.  By default, the
            client will attempt to contact the last Gateway a user connected
            to or the first one in the list from the AnyConnect profile.  In
            the case of certificate-only authentication, this will result in
            the establishment of a VPN tunnel when the client is started.
more here:
http://www.cisco.com/en/US/partner/docs/security/vpn_client/anyconnect/anyconnect25/administration/guide/ac03features.html#wp1215263
hth,
rob
Related Content
