ICM calls from IP-IVR to CVP
Aug 5th, 2010
I am trying to transfer a call from an IP-IVR server to CVP. The transfer is failing because it’s not adding a correlation ID to the transfer number and CVP does not know how to process the call.
How do I get it to add a correlation ID. The IP-IVR is a type 2 and the CVP is a type 10
Calls that go direct to CVP from CM work fine.
Graham
geoff@hp.com Thu, 08/05/2010 - 13:44
You would need the old form of translation route then.
With CVP3 you needed to create a different CVP - a Type 2 NVRU. But with CVP7, the Type 10 will do it.
Geoff
Graham Old Thu, 08/05/2010 - 13:59
It is CVP 7.0(1) ICM 7.2.6 and IP-IVR 7.0(1)
I can see in the MIVR logs the number is just 6111111111 with no correlation ID.
The CVP just sends the call to the error message on 9292929292
Graham
Related Content
