1941W bridge issues
Aug 5th, 2010
I'm trying to setup a (what I think to be) simple wireless network using a Cisco 1941W integrated services router. Currently running this on a test environment behind a little Linksys router/modem combo (at 192.168.0.1). I would like to use the 2.4ghz radio as a root access point for clients to gain access to both the wired network (currently at 192.168.2.0) and the external network (currently at 192.168.0.1). Wireless clients are set to 192.168.1.X.
I can ping external IPs from the router (ie google.com), ping all the interfaces on the AP (BVI interface and clients). From the AP I can ping all the interfaces on the router, I can't however leave the router at all (ie ping 192.168.0.1, google). Been playing with this for a while so there might be some extras in my config but:
Router Config:
! Last configuration change at 22:59:21 UTC Thu Aug 5 2010
version 15.0
hostname YTCamsRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$..KB$Qa/M2FDZkxqAHydIMyFDk1
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.201 192.168.1.254
ip dhcp pool ytexternal
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 192.168.1.1
ip name-server 8.8.8.8
ip name-server 4.4.4.4
ip name-server 192.168.0.1
license udi pid CISCO1941W-A/K9 sn FHK140573YT
username SAadmin privilege 15 secret 5 $1$izd3$bv13qI3qWRcgT6a7YivWc1
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
interface GigabitEthernet0/0
description internal interface
ip address 192.168.2.1 255.255.255.0
ip access-group from-lan in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description external interface
bandwidth 1000
ip address 192.168.0.200 255.255.255.0
ip access-group from-lan out
ip nat outside
duplex auto
speed auto
interface FastEthernet0/0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip access-list extended nat-list
permit ip 192.168.0.0 0.0.0.255 any
permit tcp 192.168.1.0 0.0.0.255 any
control-plane
line con 0
password xxxxx
login
line aux 0
line 67
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password xxxxxx
login
scheduler allocate 20000 1000
end
AP Config:
version 12.4
no service pad
service password-encryption
hostname ap
no logging buffered
enable secret 5 $1$iTve$jLo12l8pXiW6fzZ34B5fg1
no aaa new-model
dot11 syslog
dot11 ssid YTGuest
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 033D0B1E080832581E1E17
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
ssid YTGuest
antenna gain 0
station-role root access-point
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.1.3 255.255.255.0
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
show ip route from the router:
YTCamsRouter#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.0.1
      192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.0.0/24 is directly connected, GigabitEthernet0/1
L        192.168.0.200/32 is directly connected, GigabitEthernet0/1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, Vlan1
L        192.168.1.1/32 is directly connected, Vlan1
      192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.2.0/24 is directly connected, GigabitEthernet0/0
L        192.168.2.1/32 is directly connected, GigabitEthernet0/0
YTCamsRouter#
Just for good measure, a show IP Interfaces brief from the router
Interface                  IP-Address      OK? Method Status                Prot
ocol
Wlan-GigabitEthernet0/0    unassigned      YES unset  up                    up
GigabitEthernet0/0         192.168.2.1     YES manual up                    up
wlan-ap0                   192.168.1.1     YES TFTP   up                    up
GigabitEthernet0/1         192.168.0.200   YES manual up                    up
FastEthernet0/0/0          unassigned      YES NVRAM  administratively down down
FastEthernet0/0/1          unassigned      YES NVRAM  administratively down down
Vlan1                      192.168.1.1     YES NVRAM  up                    up
NVI0                       192.168.2.1     YES unset  up                    up
YTCamsRouter#
Thanks in advance.
Jeffrey Keown Tue, 08/10/2010 - 11:42
  • Cisco Employee,
Hi Jeff,
I don't see a default gateway configured  on the ap.
looks like it should be 192.168.1.1
