ASA boot loop infinite
Aug 5th, 2010
Hi all,
Our firewall boot loop infinite, i try to stop it to getting crashinfo file but i couldn't. I used password-recovery but boot loop still exist, for ROMMON mode, no command to show files in flash or disk0. how can i do? In addition, i would like to re-upload image file to ASA but i'm not sure, can i upload the identical image to device or i need to delete it first?
Nagaraja Thanthry Thu, 08/05/2010 - 21:16
What code version you are running on the firewall right now? Where there any
hardware/software changes after which it started rebooting? Can you post
some screen shot of the reboot messages that you are seeing?
Nagaraja Thanthry Thu, 08/05/2010 - 21:55
Do you have this device in a failover pair? Can you disconnect all the
cables and reboot this device in stand-alone mode? Most likely you might be
hitting a bug. The outputs indicate that the device crashes when it is
checking for interface status. Removing the device from failover might help
alleviate the issue.
Hope this helps.
Rojer-bkk Thu, 08/05/2010 - 22:13
Yes, already unplug all cabling from firewall but problem still occurring and firewall couldn't write dump file in flash, actually firewall was enabled feature to saved
