How to Block Netbios
Aug 5th, 2010
I have cisco 1800 series router and i want to block Netbios on that.
Jayakrishna Mada Thu, 08/05/2010 - 23:49
Hi Prasad,
Do you have ip helper addess configured on the switch if yes then configure
no ip forward-protocol udp 137
no ip forward-protocol udp 138
no ip forward-protocol udp 139
if not you can configure and apply this access-list:
access-list 110 deny   tcp any any range 137 139
access-list 110 deny   udp any any eq netbios-ss
access-list 110 deny   udp any any eq netbios-dgm
Hope this helps.
PRASAD BAIT Mon, 08/09/2010 - 06:10
Hi Jayakrishna,
thanks for your support.
But plz tell me that is there any need to configure the ip helper address or not???
