Conference Causes Dropped Calls
Robert Juric
I've got a user that when he attempts an ad-hoc conference and attempts the joing the second line the conference, it just disconnects both lines.
What could be causing the conference to disconnect the calls?
Jaime Valencia
Most likely it's a codec issue, check they're all using G711 if using SW CFB or add a XCODER.
If HW CFB make sure relevant codecs are under the dspfarm profile.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
