Access from dmz to internet, where internet and inside lan are on same interface
Aug 6th, 2010
I have a scenerio, my outside and inside network are connected via inside interface of my firewall pix. And dmz is connected via dmz. Inside has security level 100 and dmz has 40,
from dmz i can access inside lan, but not able to access internet. KIndly help.
Nagaraja Thanthry Fri, 08/06/2010 - 06:05
  • Cisco Employee,
Do you have NAT rules configured to access internet from DMZ?
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
In the above example, the outside interface IP address will be shared by
both the inside and dmz clients when going to internet. Please make sure
that you have something similar configured. Also you need to check the
following things:
-- There are no access-list entries on the DMZ to block internet connection
-- You have access to the DNS server (if DNS server is on the inside subnet,
please configure a static NAT rule for the DNS server)
-- If you are using ASA5505 with base license, you will not be able to
communicate between the inside and outside simultaneously.
Hope this helps,
NT
ashish_kandari Fri, 08/06/2010 - 06:16
but i dont have any outside interface configured.....
Outside- router---inside --firewall---dmz.
Outside and inside are on same side of firewall...
this config :
I thnk as traffic is movig from lower to higher security level, we need a static nat.
But how can i use a static nat for all internet address, there is no option of wild card in static nat..
thanks in advance..
ashish
Nagaraja Thanthry Fri, 08/06/2010 - 06:26
  • Cisco Employee,
In that case, you can disable NAT control and remove the existing NAT
configurations.
ASA#configure terminal
ASA(config)#no nat-control
ASA(config)#clear configure nat
ASA(config)#clear configure global
ASA(config)#clear configure static
Since you have disabled the NAT requirement, all traffic will go to your
outside router without any NAT. Make sure that the outside router has a rule
to accommodate DMZ subnets in the NAT pool.
Hope this helps.
NT
ashish_kandari Fri, 08/06/2010 - 06:30
i can check that, but for that i will need down time... as some connection will also dro
p.. second thing.... for traffic from lower to higher security level, dont we need static nat. ......
Nagaraja Thanthry Fri, 08/06/2010 - 06:40
  • Cisco Employee,
You do not need any NAT rule when you are going from lower security
interface to higher security interface.
NT
ashish_kandari Fri, 08/06/2010 - 06:06
static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.0.0.0 0 0
static (dmz,inside) 10.0.0.0 10.1.1.1 netmask 255.255.255.255 0 0
nat (dmz) 2 10.2.1.2 255.255.255.248 0 0
nat (dmz) 2 10.2.3.0 255.255.255.224 0 0
nat (dmz) 2 10.7.1.32 255.255.255.224 0 0
global (inside) 2 interface
will this help...
Nagaraja Thanthry Fri, 08/06/2010 - 06:12
  • Cisco Employee,
Few concerns:
This statement seems to be incorrect.
Why are you mapping DMZ traffic to inside interface IP?
You do not need to statically map DMZ addresses to inside address unless
they are some servers. If you were trying to map the DNS server, your first
statement (static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.0.0.0) takes
care of it.
Hope this helps.
NT
ashish_kandari Fri, 08/06/2010 - 06:20
This is becoz..dmz and inside are using approx same kind of ip range means.. 10.*.*
becoz of this command access from dmz to inside is possible, but not towards internet......
In my firewall outside interface traffic is not even reaching,.. its getting dead before it.. some natting issue.
want to so that it will take inside ip addresss to go to internet...
care of it.
